Can anyone help find a suitable replacement for the following IC?
I have a SMPS few boards SMPS with two different revisions.
IC size SOT23-6
One revision uses 61A51a or 61G52 this IC has:
- pin 1 (connected to voltage divider: + 100k | 22k - )
- pin 2 GND
- pin 3 FB (connected to optocoupler)
- pin 4 (connected MOSFET 12N65 source,) maybe sense
- pin 5 Drive (connected to MOSFET gate via transistor W2A 42)
- pin 6 VCC
On the other revision, the board changed only the PWM IC and the correspondent traces.
The PWM IC is marked 6853K45. It looks like the CR6853, pin compatible to SG6848 and others.
- GND pin 1
- FB pin 2
- RI pin 3
- Gate pin 6
- VCC pin 5
- Sense Pin 4
