6
I heard stranded copper wire would be silver-coated for better conductivity at high frequencies (skin effect). But silver is at least an order of magnitude more expensive than copper, yet only has 5% more conductivity. Is silver actually used for this?
    \$\begingroup\$ I dunno about silver-plating, but litz wire is definitely a thing, and that is much more costly than silver-plating would be. \$\endgroup\$
    – The Photon
    Commented Aug 6, 2013 at 16:32
Yes. Silver Plating is a commonly used plating material for conductivity. (There is also some debate whether silver helps in preventing tarnish or corrosion compared to bare copper, see this NASA Research PDF). Silver by the pound is more expensive than Copper (~20 dollars for one ounce of silver to ~19 cents for an ounce of copper), but we are talking about plating. A very very thin layer of electro-chemically adhered silver is very cheap in comparison to a single strand of copper wire. Typical plating thickness is just 2µm or greater. The same is done with tin or nickel or gold (Gold being ~1,283 DOLLARS PER OUNCE)
As the Science World advertisement goes: enter image description here
Gold is a soft metal that can be easily shaped and stretched. A single ounce of gold can be hammered into a square sheet 30 m on each side or drawn into a wire that would stretch 8 km. Gold leaf can be beaten thin enough to become translucent. Scientists call the ability to be flattened malleability and the ability to be stretched ductility.
1oz into a 30m^2 area (of undetermined thickness). Plating is very cost effective for what you get. (And that's why gold plated audio connectors can be had for pennies. You are only getting a fraction of a fraction of a fraction of gold.)
  • \$\begingroup\$ I don't think silver plating is used for its anti-tarnish properties. \$\endgroup\$
    – The Photon
    Commented Aug 6, 2013 at 16:46
  • \$\begingroup\$ I guess gold won't be used for the plating/coating of wire, though: its conductivity is lower than that of copper, and like the Photon says the reason won't be anti-corrosion either. \$\endgroup\$
    – Johan.A
    Commented Aug 6, 2013 at 16:47
    \$\begingroup\$ @Johan.A: Historically, electropneumatic pipe organs often used silver wires as relay contacts. Silver oxide isn't a great conductor, but its resistance is far lower than that of copper oxide. \$\endgroup\$
    – supercat
    Commented Aug 6, 2013 at 16:51
  • \$\begingroup\$ @supercat: yes, but you're talking about switch contacts. I was thinking of (insulated) connection wire. I've never seen gold used for that. \$\endgroup\$
    – Johan.A
    Commented Aug 6, 2013 at 16:54
    \$\begingroup\$ @Johan.A the mentioning of gold is an example of a high cost material being used as plating. Gold being (today) $1283 to Silver's $19.55 to Copper's ¢19 per ounce. It's mentioned to show that yes, they are typically used, and how they are used (very thin electrochemically added layers) in comparison to copper (1 ounce of silver will cover many many pounds of copper). \$\endgroup\$
    – Passerby
    Commented Aug 6, 2013 at 17:02
