I understand that flash memory is used to store some program in microcontroller, it's erase programmable. But after look at HC-05 bluetooth module, there are 2 chips on the board. One chip is CSR bluetooth core-4 and one chip is for flash 2Mbit (seen on datasheet here!).
My Questions are:
  1. What is flash usage here? is every bluetooth module had to have a flash chip? is it for writing and erasing data spread tranceived by bluetooth over and over?
  2. On the datasheet it is stated that 2Mbit flash . From my prior knowledge bit usually bit referencing for speed not for storage (byte). or is it typo?
6
The external Flash is almost certainly storing the firmware for the CSR chip. A Bluetooth stack is not a small or simple piece of software. The use of off-die flash is probably for cost reasons, I believe it's difficult to integrate large amounts of flash with normal CMOS logic chips.
    \$\begingroup\$ Also it's user updatable/replaceable firmware. \$\endgroup\$
    – Passerby
    Commented Sep 9, 2013 at 9:08
  • \$\begingroup\$ Also for non-vloatile parameter storage (e. g. address) \$\endgroup\$
    – DoxyLover
    Commented Sep 9, 2013 at 17:47
I can answer part 2): No that is not a typo.
Memory chips (DRAM, SRAM, flash, EEPROMS, etc etc.) are often sized in bits.
If you wish you can divide by eight to get the size in standard bytes.
(Usually by 8. Some systems like older mainframes use different byte sizes. E.g. 10 bits)
