I bought a Metcal STSS-PS2V-02 soldering iron from eBay, it was cheap and in need of repair. The previous owner had some problems with the handpiece and tried to fix it himself.
I can't get it to heat up at all.
If I turn the base station on without the handpiece connected, it draws virtually no power. With it connected, about 10W.
It appears that he has sawn the handpiece in two, then attempted to resolder the cable. With no soldering tip attached, I am seeing 0Ω between the inner and wire and sheath of the cable, does this mean that his resoldering has shorted it, or should I expect this?
Next week, I'll be able to test the base station against a known working handpiece and determine if the base is working properly, but is there any other way I can tell?
