I am designing a LED driver circuit using LT3475EFE-1#PBF IC for controlling two LEDS. I have a signal from an I/O pin for LED ON-OFF control which is tied to PWM input (as recommended). Typical circuits tie an NFET to the cathode of LED and the gate is controlled by PWM input.
Can I connect my control signal to PWM pin and perform LED lighting without using a NFET? I don't want to achieve LED dimming control, just switching action is enough.
Any help would be appreciated as I need to design the circuit in mass scale.
