I'm really just getting my feet wet when it comes to IR protocols and IR codes in general, so my knowledge and understanding may be a bit shaky here.
I am a programmer and am trying to create a tool to convert Pronto Hex codes to RAW IR pulses. To do this I'm trying to understand the process manually. I'm testing this with an IR blaster app on a specific device.
What I have so far is the result of lots of searching, playing around with tools and piecing things together.
Considering the following HEX code:
0000 006E 0011 0006 0012 0052 0014 0051 0014
0051 0014 0051 0013 0052 0013 0052 0024 0051
0014 0031 0014 0052 0023 0052 0034 0051 0014
0051 0014 0052 0013 0052 0013 0052 0014 0051
0014 0632 0154 0051 0014 0CE5 0154 0051 0014
0CE5 0154 0051 0014 0CE5
Here is pseudocode of what I have
I know the first set, "0000", indicates it's raw oscillated code. I believe the second set "006E" indicates the frequency for the code and can be converted to khz via:
freq = 1000000 / (toDecimal("006E") * .241246)
I know that the third and fourth sets of codes have to do with the sequence lengths.
I know the rest of the sets can be converted to pulses in microseconds with the following, using "0012" as an example
microSeconds = 1000000 * toDecimal("0012") / freq
So "0012" would be (rounded) 478. So, applying the above to the full code and separated with commas I end up with:
478,2176,531,2150,531,2150,531,2150,504,2176,504,2176,955,2150,531,1300,531,2176,929,2176,1380,2150,531,2150,531,2176,504,2176,504,2176,531,2150,531,42088,9023,2150,531,87599,9023,2150,531,87599,9023,2150,531,87599
When I test this out with an IR blaster I don't see the device I am trying to control respond. However if I prepend the opening pulses for NEC protocol 9000,4500 I get a response from my device.
My questions are - Could someone tell me if I am on the right track here? How would I discern from the HEX code that I needed to use the 9000 on 4500 as the opening pulses? Any input/advice would be really appreciated, as I've said I'm just getting my feet wet here. Thanks much!
