Going through some past exams, I've came across this question;
question
To get started, I've noticed that it resembles to the frequency differentiation property; working
Now, the differentiation was extremely messy, and as a result, the second derivative was worse than the first
Is there another property that I can use to simplify this problem or the only is using this derivative? The formula sheet we used for this paper is here and here
I would treat it as two step functions added together by splitting the absolute value.
t^2*exp(-4*(t-5))*u(t-5) + t^2*exp(-4*-(t-5))*u(-t+5) - dirac(t-5)
Then you can use the "nth-order time-rising causal delay exponential function" transform. Since they're added together, you can use superposition. The dirac part of it removes the discontinuity that would occur at t=5.
  • \$\begingroup\$ But for that "nth-order time-rising causal delay exponential function" you need all the t's to be the same, in this case some are shifted by 5, you can't use that. \$\endgroup\$
    – asd
    Commented Dec 17, 2021 at 0:07
