I'm building a dispatcher for PIC microcontrollers to switch tasks saving their contexts.
The dispatcher is triggered when an interrupt occurs. The problem is that the compiler I'm using (C18 V3.x) saves/restores the context automatically when an interrupt occurs, but I don't know how to recover the information saved.
I want to disable the automatic saving of the context and make it by myself, choosing just the registers I want to save.
Part of the ISR's code is:
void isr_dispatcher()
uint8 w_temp, status_temp, bsr_temp;
INTCONbits.GIE = 0;
// save the context
_asm
movwf w_temp, 0
movff STATUS_REG, status_temp
movff BSR_REG, bsr_temp
_endasm
When an interrupt occurs (TMR0 overflow, in my case), isr_dispatcher begins to execute. The problem is that the compiler translates my isr_dispatcher to this assembly code:
!void isr_dispatcher()
0x1308: MOVFF FSR2H, PREINC1
0x130A: NOP
0x130C: MOVFF FSR1H, FSR2H
0x130E: NOP
0x1310: MOVFF FSR0, PREINC1
0x1312: NOP
0x1314: MOVFF FSR0H, PREINC1
0x1316: NOP
0x1318: MOVFF TBLPTR, PREINC1
0x131A: NOP
0x131C: MOVFF TBLPTRH, PREINC1
0x131E: NOP
0x1320: MOVFF TABLAT, PREINC1
0x1322: NOP
0x1324: MOVFF PROD, PREINC1
0x1326: NOP
0x1328: MOVFF PRODH, PREINC1
0x132A: NOP
0x132C: MOVFF PCLATH, PREINC1
0x132E: NOP
0x1330: LFSR 0, 0x0
0x1332: NOP
0x1334: MOVLW 0x14
0x1336: DECF WREG, W, ACCESS
0x1338: BNC 0x1340
0x133A: MOVFF POSTINC0, PREINC1
0x133C: NOP
0x133E: BRA 0x1336
0x1340: LFSR 0, 0x14
0x1342: NOP
0x1344: MOVLW 0x7
0x1346: DECF WREG, W, ACCESS
0x1348: BNC 0x1350
0x134A: MOVFF POSTINC0, PREINC1
0x134C: NOP
0x134E: BRA 0x1346
0x1350: MOVF POSTINC1, F, ACCESS
0x1352: MOVFF FSR2, POSTINC1
0x1354: NOP
0x1356: MOVFF FSR1, FSR2
0x1358: NOP
0x135A: MOVLW 0x3
0x135C: ADDWF FSR1, F, ACCESS
! uint8 w_temp, status_temp, bsr_temp;
! INTCONbits.GIE = 0;
0x135E: BCF INTCON, 7, ACCESS
! // save the context
! _asm
! movwf w_temp, 0
0x1360: MOVWF nova_tarefa, ACCESS
! movff STATUS_REG, status_temp
0x1362: MOVFF STATUS, status_temp
0x1364: NOP
! movff BSR_REG, bsr_temp
0x1366: MOVFF BSR, bsr_temp
0x1368: NOP
! _endasm
As you can see, the compiler inserts several assembly instructions before my original isr_dispatcher code. I wish the compiler did not do it. Just so I could save the context.
