I have a slight doubt here. Can the outputs of 2 boost converters set to output the "same" voltage (isolated, they would never be exactly the same obviously) be safely tied together, as long as there is a capacitive load? If so, is there a minimum to that load?
Context:
I need at least 4Ah of battery capacity, and I was only able to find single cells charger+boost modules, so I have to put them in parallel. It's for long term logging, the current is very low: 30mA peak, and around 5mA 99% of the time.
