In designing a 3 Phase, 4 Pole, 24 Slot AC machine assuming a RYB phase sequence i am confused on the starting point of the blue phase. The calculations, table and diagram look like the following.
Calculations:
$$m = \frac{24}{3\times4} = 2 \hspace{0.2cm}\text {Slots per pole per phase}$$
$$\text{Phase Spread} = m\times\beta = 2\times \frac{180}{\text{slots per pole}} = 2\times \frac{180}{24/4} = 60^{\circ}$$
$$\text{Coil span} = \frac{24}{4} = 6 \hspace{0.2cm} \text{slots}$$
Now using the coil span and 4 poles we can create the slot table.
Table:
Representation of each Coil assuming a convention of current under north pole with a right arrow.
Diagram
Question: I understand how the red and yellow phases are wired, however the blue phase is confusing. Why is it shifted? Why are we not starting the blue phase at coil 3 and ending at coil 21 like the other two phases?
I understand that even though we are assuming a RYB sequence in the winding diagram the order in which the phases appear is RBY. I believe this is because when three phase is passed through the coils the order in which current is induced is RBY. This is best explained in the diagram below.
Is this why we are starting the blue winding in a shifted sequence?
