I have a 30MHz Crystal Oscillator to clock a PIC24FJ128GC010 Controller. I am programming in MPLAB X. My idea is to generate a pulse on one of the I/O pin toggling. But unfortunately, I cannot do so. Initially I was using a 8MHz Crystal. I have made the Configuration Word settings as well as Control Register adjustments. I have changed the baud rate too.
Please suggest the possibilities in this case.
CONFIG WORDS
POSCMD = HS // Primary Oscillator Select (HS Oscillator Enabled)
OSCIOFCN = OFF // OSCO Pin Configuration (OSCO/CLKO/RC15 functions as CLKO (FOSC/2))//
FCKSM = CSDCMD // Clock Switching and Fail-Safe Clock Monitor Configuration bits (Disabled)
FNOSC = PRI // Initial Oscillator Select (Primary Oscillator (XT, HS, EC))
IESO = OFF // Internal External Switchover (Disabled)
#include "timer.h"
unsigned millisCount = 0;
void __attribute__ ((interrupt, no_auto_psv)) _T2Interrupt(void)
IFS0bits.T2IF = 0;
millisCount++;
* Returns the number of milliseconds since the device was started as an
* unsigned long.
unsigned long Millis()
return millisCount;
void ResetMillis(void)
millisCount = 0u;
void Delay(unsigned long delayTime)
volatile int delayStart = Millis();
while (Millis() - delayStart < delayTime);
INITIALISATION CODE
void Osc_Config(void)
OSCTUN = 0;
CLKDIV = 0;
OSCCON = 0;
OSCCONbits.COSC = 2;
OSCCONbits.NOSC = 2;
OSCCONbits.OSWEN = 1;
while(OSCCONbits.OSWEN);
void Timer2_Config(void)
T2CON = 0;
TMR2 = 0x0000; //Turn off Timer2
PR2 = 0xFFFF; //Period register at maximum
_T2IF = 0; //clear Timer2 interupt flag
_T2IE = 1; //Enable Time2 interupt
//T2CON
T2CONbits.T32 = 0; //Timer2 and T3 or T4 and T5 act as two 16-bit timers
T2CONbits.TCKPS = 0; //Timer Prescale 1:1
T2CONbits.TGATE = 0; //Gated time accumulation is disabled
T2CONbits.TSIDL = 0; //Continues module operation in Idle mode
T2CONbits.TCS = 0; //Internal clock (FOSC/2)
T2CONbits.TON = 1; //Starts Timer2
void Io_Config(void)
****//Start pulse pin**
PULSE_PIN = 0;
TRISBbits.TRISB2 = 0; //set as output pin**
//Stop pulse pin
TRISBbits.TRISB15 = 1; //set as input pin
TRISCbits.TRISC1 = 1; //set as input pin for current
TRISBbits.TRISB13 = 1; //set as input pin
//Trip point pin
TRISBbits.TRISB5 = 0; //set as output pin
// Configure start and stop pulse as digital
ANSBbits.ANSB2 = 0; //set as digital
ANSBbits.ANSB15 = 0; // set as digital
ANSCbits.ANSC1 = 1; // set to analog
ANSBbits.ANSB13 = 0; // set to digital
ANSBbits.ANSB12 = 0; //Set to Digital to check the frequency of the Oscillator
//reference clock output
ANSBbits.ANSB15 = 0; //seta s digital
TRISBbits.TRISB15 = 0; //SSet as output
} <-- NOTE: was missing trailing brace here.
void Adc_Config(void)
PMD1bits.ADC1MD = 0; //Clear PMD bit to allow ADC operation
//ADCON1
ADCON1bits.ADSIDL = 0;
ADCON1bits.ADSLP = 0;
ADCON1bits.FORM = 0;
ADCON1bits.PUMPEN = 0;
ADCON1bits.ADCAL = 0;
ADCON1bits.PWRLVL = 1;
//ADCON2
ADCON2bits.PVCFG = 0;
ADCON2bits.NVCFG0 = 0;
ADCON2bits.BUFORG = 1;
//ADCON3
ADCON3bits.ADRC = 0;
ADCON3bits.ADCS = 0;
ADCON3bits.SLEN0 = 1u; //FKo
ADCON1bits.ADON = 1;
while(ADSTATHbits.ADREADY == 0); // Wait for ready flag set.
//Make sure ADC sample lists and Accumulator feature are in known states
ACCONH = 0x0000; //Disable accumulation for the moment
ACRES = 0x00000000; //Clear previous accumulation count
ADL0CONLbits.SLSIZE = 1-1; //Sample list length for 1 channel
//Configure Sample List 0 settings
ADL0CONHbits.ASEN = 0;
ADL0CONHbits.SLINT = 1;
ADL0CONHbits.WM = 0;
ADL0CONHbits.CM = 0;
ADL0CONHbits.SAMC = 1;
ADL0CONLbits.SLTSRC = 0;
ADTBL0bits.ADCH = 8; // channel 0 selected
ADL0PTR = 0; // Point to start of sample list 0
#if (__TEST_FREQUENCY_SETUP__)
ADL0CONLbits.SAMP = 1;
Nop();Nop();
ADL0CONLbits.SAMP = 0;
while(!IFS0bits.AD1IF && !ADSTATLbits.SL0IF) { ; }
IFS0bits.AD1IF = 0u;
ADSTATLbits.SL0IF = 0u;
unsigned long res = ADRES0;
res = 15u;
#endif <-- NOTE: was missing.
} <-- NOTE: missing.
void Uart_Config(void)
RPOR1bits.RP2R = 3; //Assign UART1 transmit to RP3 Peripheral
RPOR1bits.RP3R = 4;
RPINR18bits.U1RXR = 0; //Assign UART1 RXD to RP0 Peripheral
RPINR18bits.U1CTSR = 1;
U1BRG = 50;//12;
U1STA = 0;
U1MODE = 0x8000;
U1STAbits.UTXEN = 1;
**#define UART_BUFFER_SIZE 128
void UARTInit(void)
//U1BRG = 312; //9600 baudrate @ 24MHz osc
U1BRG = 24; //19200 baudrate @ 10 MHz osc
U1MODE = 0;
U1MODEbits.BRGH = 1;
U1STA = 0;
U1STAbits.URXISEL = 0;
U1MODEbits.UARTEN = 1;
IFS0bits.U1RXIF = 0;
void UARTPutChar(uint8_t ch)
while(U1STAbits.TRMT == 0);
Nop(); Nop();Nop(); Nop();
U1TXREG = ch;
void UARTPutInt(int32_t data)
int j;
char string[UART_BUFFER_SIZE];
sprintf(string, "%ld", data);
j = 0;
while(string[j] != 0)
UARTPutChar(string[j]);
j++;
if(j >= UART_BUFFER_SIZE)
break;
void UARTPutString(char* string)
while(*string != 0)
UARTPutChar(*string);
string++;
void UARTPutDouble(double data)
int j;
sprintf(string, "%9.3f", data);
j = 0;
j++;
break;
char UARTWaitChar(void)
while(IFS0bits.U1RXIF == 0);
return U1RXREG;
char UARTGetChar(void)
if(IFS0bits.U1RXIF == 0)
return 0;
U1STAbits.OERR = 0;
return U1RXREG;
MAIN CODE
// PIC24FJ128GC010 Configuration Bit Settings
#define STARTUP_DELAY (5) //Time spent waiting after device start up
#define ZERO_SET_TIME (5) //Time spent setting the zero level
#define COUNT 5
#define DELAY for(i=0;i<COUNT;i++)
int dispOffset = 0;
void SetDutyCycle(int nDC); //Set duty cycle for trip point
int PulseMeasure(void); //Single pulse measurement
int LevelMeasure(int, int); //Averaged return of multiple measurements
int adctemp;
void TestMeas(void); //Test routine to scan through PWM values
double StdDev(int, double, double, double);//Get sigma for measurements
int i;
* Main
int main(void)
//Configure all of the devices
while (Millis() < STARTUP_DELAY); //Wait for settling...
//Wait for sensor to be plugged in
**while(LevelMeasure(CTMU_BUFFER_POWER, OVER_SAMPLE) < 0);**
while(Millis() < 10) { ; }
ResetMillis();
LATBbits.LATB2 = 1;
ResetMillis();
LATBbits.LATB2 = 0;
#endif
} <-- NOTE: missing brace.
volatile unsigned int Vread;
double Vtot = 0;
int j;
//ADL0CONLbits.SAMP = 1; //Sample
PULSE_PIN = 0;
CTMUCON2 = CTMUCON2 & 0xFCFF;
CTMUCON1bits.IDISSEN = 1; //discharge cap
Delay(20);
CTMUCON1bits.IDISSEN = 0; //Release cap from discharge
ADL0CONLbits.SLEN = 1;
for(j=0;j<10;j++)
Nop();Nop();Nop();Nop();
Delay(1);
PULSE_PIN = 1;
PULSE_PIN = 0;
while(!CTMUCON2bits.EDG1STAT);
while(ADSTATHbits.ADBUSY);//{;}
Nop(); Nop();
IFS0bits.AD1IF = 0;
ADSTATLbits.SL0IF = 0;
ADL0CONLbits.SAMP = 0; //Conversion
while (!ADSTATLbits.SL0IF);
Vread = ADRES0;
IFS0bits.AD1IF = 0;
UARTPutString("#gy;1;");
UARTPutInt(Vread);
UARTPutString("\r\n");
return (Vread);
PULSE_PIN is the function for the pulse generation. Excuse me for the lengthy code and number of edits. But I really do not understand why the program runs well at 8MHz and not 30MHz! And YES; it really is a 30MHz crystal oscillator.
PLEASE HELP ME!!! I am new to programming but I must work with this code to run it at 30/2=16MHz for further work.
