Homework: I am trying to wrap my head around converting a capacitor circuit into an equivalent capacitor. I have looked at resources saying that it is the same as delta-wye transformation of resistors, but in reverse. I thought I had the process right, but I keep getting the wrong answer.
      24       48
a-----)|---o---|(---o
           | \ 4    |
        8 |(  |(   |( 24
b-----|(---o---)|---o
      10       30
I combined the 48 and 24 into one, then took a Delta-wye transform:
      24        16
a-----)|---o----|(----o
          C2 |(    )| C3
                o
               |( C1
b-----|(--------o
      10
The calculations I used were as follows:
4*8 + 4*30 + 8*30 = 392
C1 = 392/4 = 98
C2 = 392/30 = 13.1
C3 = 392/8 = 49
Plugging in those numbers the equivalent capacitance should be:
Ceq = (24^-1 + 98^-1 + 10^-1)^-1 + 13.1 + (16^-1 + 49^-1)^-1 = 31.7
Unfortunately this is the wrong answer. I'm not sure what i'm doing wrong, Please help.
    \$\begingroup\$ I don't see any need for D-Y here. \$\endgroup\$
    – user16324
    Commented Jul 19, 2015 at 22:01
Allow me to draw it in a different way:
Circuit Rearranged
Now have another go at solving the problem.
A final hint: You will need to use the following two equations a total of 5 times (one equation is used twice, and the other three times).
$$\frac{1}{C_{series}} = \frac{1}{C_{1}} +\frac{1}{C_{2}} +...$$
$$C_{parallel} = C_1+C_2+...$$
  • \$\begingroup\$ p.s. the answer starts with a 5. But that's all I'm saying ;) \$\endgroup\$ Commented Jul 19, 2015 at 23:04
  • \$\begingroup\$ Wow, I definitely made it more complicated than needed. Thank you @TomCarpenter. \$\endgroup\$
    – Mark Walsh
    Commented Jul 19, 2015 at 23:35
  • \$\begingroup\$ I also see where I made a mistake in my Ceq. It should have been: Ceq = 1/(1/24 + 1/10 + 1/98 + 1/(13.1+1/(1/16+1/49))) Which also equals the answer. \$\endgroup\$
    – Mark Walsh
    Commented Jul 19, 2015 at 23:39
