I'd like to find \$i_s\$ for the following circuit, using the superposition theorem. First I zero the current source, which leaves me with a circuit whose resistances can be reduced, giving us
$$R_t = (5+10)\,\parallel\,5 = 3.75\,\Omega$$
This, in accordance with Ohm's law, yields us the current \$i_1 = \frac{10}{R_t} \approx 2.67\,\text{A}\$
My first question here is about passive configuration regarding current and voltage. The passive configuration is when the current reference direction enters the positive reference of the voltage (as in our image). In this case, we have Ohm's law as \$v = iR\$.
But when the current reference direction enters the negative reference of the voltage, Ohm's law becomes \$v = -iR\$.
So that means if \$i_1\$ goes in the same direction as \$i_s\$ in the figure, \$i_1\$ is positive (as per my calculations). However, the textbook writes \$i_1 = -2.67\,\Omega\$.
For the rule I explained above, is there an exception to sources, or have I misunderstood the passive configuration's consequence on Ohm's law?
The next step to solve for \$i_s\$ is to zero the voltage source, which gives us a circuit that looks like the figure below.
Why is it that the current through the \$5\Omega\$ resistor will be \$0\,\text{A}\$?
Textbook gives us \$i_2 = -0.67\,\text{A}\$, which can be calculated using the current-division principle on the \$10\Omega\$ and \$5\Omega\$ resistors, which are apparently parallel (I don't see it, considering the \$5\Omega\$ resistor).
