I got some very small coil (OD<1cm). They are made of copper wires at 46AWG. By applying a changing voltage(sine wave), I can get a very small magnetic field (such I could attract some small magnets).
The matter is the coil fail very easily. I have checked that there is no mechanical damage (they are wrapped and protected from any mechanical damage). Also the heat dissipated is very small (at least not noticeable from touch).
It is found that the resistance of damage coil is much larger than than those good coils (Mohm vs ohm). I suppose it would be some wire damage inside...So, what would cause the breakage? Thermal? the frequency of sine wave (stressing on the thin wire)?
