I recently build an LED matrix (for LED cube) and when testing I discovered that multiple other LEDs turned on when I triggered a specific one. Upon measuring I found out that several LEDs were "damaged": The lit up when forward biased, but conducted backwards at around 1.7V. This bridged rows of the matrix and allowed other LEDs to get power.
Is this something that can happen by ESD? Or are my LEDs just very strange?
  • \$\begingroup\$ Heat, ESD and high reverse voltages can all damage LEDs. If the design puts many volts of reverse onto the LEDs then it may not be safe for all varieties of LEDs. If you have used high temperatures or lots of static charge when assembling you may have contributed to the damage. \$\endgroup\$
    – KalleMP
    Commented Oct 22, 2015 at 20:45
  • \$\begingroup\$ Do you have a schematic of the interconnections? I suspect that your expectations of it's working is just not corresponding to reality. \$\endgroup\$
    – Eugene Sh.
    \$\begingroup\$ 1.7 volts is about the forward voltage of a red LED. Are you sure all your LEDs are connected correctly? \$\endgroup\$ Commented Oct 22, 2015 at 22:59
  • \$\begingroup\$ they are white (3.3V) LEDs, all connected correctly in a matrixy pattern (each row common anode, columns common cathode) \$\endgroup\$
    – Pwnie2012
    Commented Oct 23, 2015 at 14:26
  • \$\begingroup\$ I'm seeing the same problem here with a matrix of blue LEDs 8 layers by 64 columns, some of the LEDs are behaving like 80 ohm resistors. \$\endgroup\$ Commented Feb 7, 2016 at 6:15
LEDs shouldn't get damaged as long as they are used within spec. If you didn't subject them to too much current in the forward direction or too much voltage in the reverse direction, then they should not get damaged.
However, many LEDs have a very low reverse voltage tolerance, like 5 V. Depending on how your LED cube is wired, you may be subjecting some of the off LEDs to more than their allowed reverse voltage. If these are blue or white, then even two LEDs forward may be more voltage than one LED can stand in reverse.
As always, check the datasheet.
For a more detailed answer, show a schematic of your circuit.
LED's don't light up when they get damaged or in a reverse diode condition (if you run too much current they get really bright and then die, the PN junction gets destoryed). Physics also doesn't allow for lighting up under reverse conditions, the holes and electrons have to combine at the junction and this won't happen under reverse current. The diodes won't conduct much "backwards" current either, if they do its under a breakdown condition and they burn up. Check your wiring. If your running didoes in parallel, you will have problems like this if you don't match them.
Unsolder or unwire a single LED from the matrix and check it with a meter in diode mode, it won't light up under the reverse condition.
