I'm a bit of a newbie to electrical work much more than Arduinos so I apologise if there's any inconsistency in what I'm asking!
I have a little electric vehicle project on going, a go-kart, I'm hoping to use electric motor with a built in controller that's rated for 48v at 30amps. It has over voltage protection built in and won't work if there's over 60v at the input.
The battery that I'm attempting to use to power it is composed of 18650 cells in a 16S8P arrangement which when fully charged outputs about 67.2V. And by now I presume you can work out the problem!
Is there any reliable way to step that 67v down to around the 48v mark at 30 amps? I've looked online for suitable buck converters and they either can't handle the voltage or they can't handle the amps. Can the ones I've found that handle one or the other be run in series or parallel potentially?
Many thanks!
