I used to have the transfer function given but here the root locus instead ...
Can one help with the start...
You can build the transfer function from the root locust. There are two branches leaving the origin, that means there are two poles there. Both the branches converge on a zero. The only way that can happen is if there are two zeros there. The final pole is on the left with the branch going off to negative infinity. You can recreate the transfer function from that.
