Normally the "real-world" convention could be to use RMS voltage for this kind of electric circuits. As uint128_t said, here it does not matter since values are going to be calculated with phasorial analysis and not with differential equations.
This eventually will matter when you need to calculate the exactly value of any variable in any specific time, for example how much electrical current is stored into the inductor, in time t. So in that case you will need to use differential equations in the time with sinusoidal analysis and the source voltage should be previously clarified (peak or RMS).
I will highly recommend you the Sadiku's Book, I think it is really good for self learning, go to chapter 9.4 Phasor Relationships for Circuit Elements: http://faculty.weber.edu/snaik/EE2260/alexander_sadiku_fundamentals_of_electric_circuits_4thed.pdf
