I have successfully installed and configured Eclipse for ARM development according to this excellent tutorial:
http://gnuarmeclipse.github.io/
Almost all the tutorials (including the one above) I have seen provide instructions on how to set up debugging, but I cannot figure out how to just load program to the flash memory without attaching the debugger (e.g. release version of the firmware).
One tutorial solves this problem by installing and calling st-link utility from Eclipse environment, but my current setup is already able to flash the MCU - why should I install anything else? I just want to make GDB flash the memory and exit.
So guys, how do you upload release versions of the firmware to your ARMs? Thank you for your suggestions :)
