I have a problem with this circuit
I can't write the status equation because the system that characterizes the circuit is coupled respect to derivatives of the difference of rings currents.
Let $$i_1:=i_{R_1}=i_{L_1}$$ $$i_2:=i_{R_2}$$ so, applying counterclockwise the KVLs to the two rings we obtain
$$\begin{cases} L_1\frac{\text{d}}{\text{d}t}i_1-L_2\frac{\text{d}}{\text{d}t}[i_2-i_1]+R_1 i_1=0 \\ L_2\frac{\text{d}}{\text{d}t}[i_2-i_1]-e+R_2 i_2=0 \\ \end{cases}$$
or, equivalently
$$\begin{cases} \frac{\text{d}}{\text{d}t}i_1=-\frac{R_1}{L_1+L_2} i_1+\frac{L_2}{L_1+L_2}\frac{\text{d}}{\text{d}t}i_2\\ \frac{\text{d}}{\text{d}t}i_2=-\frac{R_2}{L_2}i_2+\frac{\text{d}}{\text{d}t}i_1+e \\ \end{cases}$$
but now I don't know how to proceed to determinate the vectorial status equation $$\dot{x}=Ax+Bu$$
