Im looking to drive a 16 vac solenoid from a battery pack. Specifically I want an electric door catch to function when mains are down. I want to do this with out with out using a commercial UPS. Im not worried about doing the switch over from mains to battery; just how to get the correct form of power to that latch. Im assuming I will only need about 650-800mA of current for maybe 5 seconds per unlock event.
Ive seen 4047 multivibe based inverter designs with a center tapped transformer but I have also seen that there are some issues with most of those designs (lack of any kind of regulation.) Im also wondering If I need simulated AC or if I can just send pwm dc at the door catch and get the desired result. I've heard there is a way to do it called "peak and hold" basically do one high low switch then like 50% duty pwm on high to drive ac selonoides from DC but i have only seen this mentioned once. any advice would be appreciated.
