Thanks for reading. I was hoping someone could help me with the electronics of my project. So I am trying to drive a L980P200 - 980 nm, 200 mW, Ø5.6 mm, A Pin Code, Laser Diode. Link to spec sheet from Thorlabs. I have been browsing forever for a laser diode driver and I ended up ordering the LD3000R - Laser Diode Driver, 2.5 A Constant Current. Use this link here from Thorlabs.
I don't know if this will work. I need this laser driver to be able to modulate current at 10khz to compliment my photodetector which I will be using a lock-in amplifier with. I ended up buying Thorlab's T1G - Laser Diode Bias-T modulator (I can't post more than 2 links).
Could anyone tell me if this will work? In addition could someone tell me if I am able to drive this laser diode? The driver is rated higher than the laser diode laser= 1.5V, 200mW output power and 300-400mA driving current, while the driver=2.5 A, 7.7 V.
\$\begingroup\$ Use double line-break to create paragraphs. "thorlab" should probably be capitalised if it's a brand name. Separate the questions out at the end so that it's very clear what you're asking. +1 for proper linking on first post. Welcome to EE.SE. \$\endgroup\$– TransistorCommented Jul 4, 2016 at 23:01
\$\begingroup\$ @transistor. I made a few corrections for the OP-this time. \$\endgroup\$– user105652Commented Jul 4, 2016 at 23:58
1 Answer
This may work.. On the diode datasheet, you can see that the laser power graph only goes up to 280mA, but your constant current source is going to provide 2500mA. I would suggest you find a 250mA constant current source to correctly use this diode.
Edit 9/27: the link to the old sheet for the power supply is broke, and I was redirected to the new datasheet. anything below is strictly the new sheet.
There appears to be a 5V analog control on the module that I did not see before. Using this, It would be possible to modulate the laser diode's supply using modulation, such as a 5V PWM signal, or even a voltage divider. If you decide to go the voltage divider route, then I would use values of 1k and 9k.
\$\begingroup\$ one of my goals though was to modulate the current from the driver so as long as the biasT modulator would output current in the safe operating range I would be ok. Is this not true? \$\endgroup\$ Commented Jul 5, 2016 at 19:43
\$\begingroup\$ @HunterLin I would not try modulating the current on this device, it seems to already modulate the output. \$\endgroup\$– user86234Commented Jul 5, 2016 at 20:17
