I want to know if it's possible to connect a ttl device directly to my PIC18LF4680 for serial communication via USART . I can connect the ttl device directly to my Arduino Uno without issues. This is my hardware :
The ttl device has 6 pins (dtr , rxd , txd , vcc(3.3v or 5v) , cts, gnd) .
I have two different codes snippets below that perform USART communication.
Version one(I) utilizes the "usart.h" peripheral library. Version two(II) uses "TXREG" and "RCREG" for sending and receiving data.
Both versions run well in my virtual environment (proteus 8 professional), but not in the real world environment. Am I missing a step? Do I need a special library? Or is it not possible with this chip?
Version I ---------------------------------------
#include "fuses.h"
#include <p18lf4680.h>
#include <stdio.h>
#include <stdlib.h>
#include <plib/usart.h>
void main(void) {
TRISB = 0x00;
OSCCON = 0x76; // 8mhz (0111 0110)
LATBbits.LATB4 = 0;
LATBbits.LATB1 = 0;
LATBbits.LATB0 = 0;
unsigned char txt1[] = "Hello World \r\n";
unsigned char txt2[] = "Enter a number.... \r\n";
CloseUSART();
OpenUSART(USART_TX_INT_OFF &
USART_RX_INT_OFF &
USART_ASYNCH_MODE &
USART_EIGHT_BIT &
USART_CONT_RX &
USART_BRGH_HIGH &
USART_ADDEN_OFF ,
52);
for(int x=0;x<=20;x++){__delay_ms(50);}
// write/send intro to PC
while(BusyUSART());
putsUSART((char *)txt1);
for(int x=0;x<20;x++){__delay_ms(50);}
while(BusyUSART());
putsUSART((char *)txt2);
while(1){
sdata = ReadUSART();
switch(sdata){
case '1':
LATBbits.LATB4 = 1;
LATBbits.LATB1 = 0;
LATBbits.LATB0 = 0;
break;
case '2':
LATBbits.LATB4 = 0;
LATBbits.LATB1 = 1;
LATBbits.LATB0 = 0;
break;
case '3':
LATBbits.LATB4 = 0;
LATBbits.LATB1 = 0;
LATBbits.LATB0 = 1;
break;
default:
LATBbits.LATB4 = 0;
LATBbits.LATB1 = 0;
LATBbits.LATB0 = 0;
break;
----------------------------------------------------- Version II--------------------------------------------
#include "fuses.h"
#include <stdio.h>
#include <stdlib.h>
#define STRLEN 12
volatile unsigned char t;
volatile unsigned char rcindex;
volatile unsigned char rcbuf[STRLEN];
void USART_init(void){
TXSTAbits.TXEN = 1; // enable transmitter
TXSTAbits.BRGH = 1; // high baud rate mode
RCSTAbits.CREN = 1; // enable continous receiving
// configure I/O pins
TRISCbits.TRISC7 = 1; // RX pin is input
TRISCbits.TRISC6 = 1; // TX pin is input (automatically configured)
SPBRG = 52;
PIE1bits.RCIE = 1; // enable USART receive interrupt
RCSTAbits.SPEN = 1; // enable USART
void USART_putc(unsigned char c)
while (!TXSTAbits.TRMT); // wait until transmit shift register is empty
TXREG = c; // write character to TXREG and start transmission
void USART_puts(unsigned char *s)
while (*s)
USART_putc(*s); // send character pointed to by s
s++; // increase pointer location to the next character
void main(void) {
USART_init();
USART_puts("Init complete! \n");
INTCONbits.PEIE = 1; // enable peripheral interrupts
INTCONbits.GIE = 1; // enable interrupts
while(1)
void interrupt ISR(void)
if (PIR1bits.RCIF) // check if receive interrupt has fired
t = RCREG; // read received character to buffer
// check if received character is not new line character
// and that maximum string length has not been reached
if ( (t != '\n') && (rcindex < STRLEN) )
rcbuf[rcindex] = t; // append received character to string
rcindex++; // increment string index
else
rcindex = 0; // reset string index
USART_puts(rcbuf); // echo received string
PIR1bits.RCIF = 0; // reset receive interrupt flag
Every and All help is appreciated. Thanks!
