When thinking about "boost convertors" / "switching regulators" you have to think about current not voltage.
A good linear regulator, regulates voltage and is current limited. That is, it adjusts the voltage and prevents the output current from going over a set limit.
A switching regulator does the inverse. It adjusts the current and makes sure the output voltage is within a set range.
In your circuit, the "switch" is used to establish an average current in the inductor that is enough to supply the load AND keep the capacitor charged to a target voltage.
When first starting, the capacitor voltage is low so the pulse width ratio is made high to pump the maximum current through the inductor. This current is higher than the load current so the excess quickly charges the capacitor.
When the voltage on the capacitor is OVER the target voltage the ratio is reduced considerably, sometimes even stops completely. At that point there is no longer enough average current in the inductor to supply the load, and the capacitor will begin to discharge.
This all repeats at a high frequency and the regulator, if controlled correctly is a stable, self balancing system.
Of course the above is an over simplification. The Error Voltage = Target Voltage - Actual Output Voltage is used to slew the pulse width according to some slope or formula in a predefined manner that effectively attempts to quickly maintain the average coil current at the same level as whatever the load current is at any given time. All be it within an acceptable lag time.
