I have a custom four-layer PCB (Signal, Ground, Power, Signal) with an STM32F4 (72 MHz) connected to a Si4684 receiver and a Si4711 FM transmitter through SPI.
Enter image description here
It seems that my design has some signal integrity issues. I can communicate with the Si4711, but I can only communicate short commands with the Si4684. Communication with Si4684 fails (some bits are incorrect) when transferring the firmware image from the STM32 to the chip (large data transfer).
When I connect my logic analyzer to the Si4711 MISO pin, this turns around. No communication is possible with the Si4711, but communication with Si4684 works flawlessly. If I connect the logic analyzer to the Si4711 MISO pin and send the POWER_UP command to the Si4711, it seems like there is no reply from the chip. Probing at the Si4711 MOSI pin clearly shows that the command is being received correctly.
The behavior is the same if I run the clock at 300 kHz or 8 MHz. Unfortunately I don't have a oscilloscope available, but I guess this could be a slew-rate-issue since it's independent of the clock.
What could be the reason that I need to connect the logic analyzer to the MISO pin to get the Si4684 working, and why does this make the Si4711 stop working?
What I've tried so far: - Series termination (50 ohm, 100 ohm) on the CLK line - Adjusting the GPIO speed of the SPI pins on the STM32 (LOW, MEDIUM, HIGH). I believe this sets the slew rate of the pin. - Connecting the logic analyzer to the other SPI pins. - Double checked that I have the correct SPI mode (0,0) set
I understand that I will have to make a new design, but I would very much like some input on why this happens.
Please find layout and partial schematic below. SCK, MOSI and MISO signals are highlighted.
UPDATE: I moved the Si4711 to I²C instead, and now there are no issues.
    \$\begingroup\$ Can we see the pcb layout? \$\endgroup\$
    – kva
    Commented May 30, 2017 at 14:36
    \$\begingroup\$ What is the power supply voltage of the STM32 ? The Si4710 seems to be 2.7V to 5.5V compatible and the Si4684 is 1.8V chip. \$\endgroup\$
    – Foxrider83
    Commented May 30, 2017 at 14:55
    \$\begingroup\$ FWIW I would not expect any issues with the layout you've described at the speeds you've described. Try to obtain an oscilloscope, it's really an essential tool. The problem might be unrelated to the SPI. How is the power integrity and decoupling? Agree that posting a full schematic and PCB layout would be helpful. \$\endgroup\$ Commented May 30, 2017 at 15:56
    \$\begingroup\$ If you are using the wrong combination of modes, such that you are driving and sampling a given signal on the same clock edge rather than on opposite edges, very flaky operation could be expected, and parasitic loading of probes might fix/break things. \$\endgroup\$ Commented May 30, 2017 at 16:31
    \$\begingroup\$ @kva Layout and schematic added \$\endgroup\$
    – JohnDonut
    Commented May 30, 2017 at 22:34
I worked on sensor-head (4 channel IR camera, CMOS mux under the IndiumPhosphide laminated sensor) that absolutely would not cooperate with the control-signal-emitting FPGA until I snipped all the digital interface wires (approx. 12 of them) and inserted 1Kohm resistors to greatly slow the edges of the timing signals and thus avoid undershoot (to -5 volts) and overshoot (to +10v) on the 0v/5v interface.
In diagnosing, before inserting the 1Kohm series Rs, I looked using a realtime TEK7904 (500MHz scope, no sampling done) and P6201 (900 MHz probe at 1pF when X10 head was slipped on), I saw these horrid overshoots with 500 picosecond edges running 4" across 1 PCB, another 4" across the 2nd PCB and then running thru a 1" connector and down into the liquid nitrogen dewar.
We thus has 4+4" embedded inside PCB, with effective length of 8" (scaled by sqrt(Er)) thus 4+4 becomes 8+8, with return path making 16+16") plus connector and dewar.
Your SPI is only 3 wires. Explore where, exactly, the reflections/overshoots are best dampened.
  • \$\begingroup\$ I think that there is a conflict between those devices as he did not implement any chip select line, so both slaves try to communicate and using C language terminology it is an Undefined Behaviour :) \$\endgroup\$ Commented May 30, 2017 at 22:13
  • \$\begingroup\$ I have individual chip select lines and they are confirmed ok. \$\endgroup\$
    – JohnDonut
    Commented May 30, 2017 at 22:37
    \$\begingroup\$ @PeterJ while there were no chip selects in the original "distance" diagram, the schematic since added shows them. \$\endgroup\$ Commented May 30, 2017 at 22:39
