I'm a real novice when it comes to electrical engineering. Like a fish out of water. I want to create a self-sustaining fan for summer.
I'm trying a fan that's 240V, 35W. If I was going to run it for 8 hours, what size or power battery would I need? What would be the most efficient size/power solar panel to recharge it?
    \$\begingroup\$ Question title says 12 hours. Short answer is your battery will probably be a couple of kilograms so if you're going to be carrying it around you may want to reconsider. \$\endgroup\$ Commented Aug 30, 2017 at 4:58
    \$\begingroup\$ you probably want to reconsider a DC fan to improve motor efficiency matched to a Wh or VAh battery source i.e. car battery and a PV matched for your solar power avail/day probably >4x fan power \$\endgroup\$
    – D.A.S.
  • \$\begingroup\$ similar: electronics.stackexchange.com/questions/36273/… and electronics.stackexchange.com/questions/204794/… \$\endgroup\$
    – Arsenal
    Commented Aug 30, 2017 at 7:04
35W for 12 hours is 420 W*hr. One Li-ion 18650 cell (same as in many laptops) has capacity of about 10 W*hr. So you will need about 50 cells to keep your fan running for 12 hours. Each cell is about 45g, so the whole battery will weight about 2.2 kg, or about 5 lbs.
Now about solar. As I understand, you likely want to recharge your battery over one day, ready for another 12 hours. To recharge a 420 Wh battery over a daylight time, say 6 hours, your will need at least a 100-W solar panel, something like used for RV or boat, example on eBay. The thing will have 40" x 26" x 1.2" in size, and weight of 19 lbs (8.5 kg). Most likely you will need a bigger panel, since this one makes only 300 Wh over a sunny day, so you might need to double the panels.
ADDITION: I forgot to mention that in order to"create" a self-sustainable solar power system, you will also need:
(a) solar controller/stabilizer;
(b) balanced battery charger (to charge all cells evenly);
(c) power management electronics, to balance input between the charger, battery, and outlets;
(d) durable enclosure with proper connectors/outlets;
(e) mounting harware for solar panel, to follow the Sun, at least manually.
The project will take likely a full year for a team of several engineers. Alternatively you can shell out some sizable money ($500 - $1000) and get a professionally built product, like the 400 Wh "Goal Zero Yeti solar station".
  • \$\begingroup\$ Plus you may want to run the fan while charging, so add solar panel area for that too. \$\endgroup\$
    – user16324
    Commented Aug 30, 2017 at 11:36
    \$\begingroup\$ "The project will take likely a full year for a team of several engineers." ... What is your basis for that comment? The rest of your answer seems great but I don't see where there is multiple man years of work for professionals. \$\endgroup\$
    – Squats
    Commented Aug 30, 2017 at 22:59
