I am working on a project, which may eventually be used commercially, so I want to ensure that it is safe.
It has a 80Amp 12v power supply. It is controlled by a touch screen, with switches to control different systems.
It needs to control 4 separate LED panels, each of which draw 7.2 Amps. It needs to control 6 linear actuators. 4 of the actuators can be tied together, and draw 5 Amps each. 2 of the actuators can be tied together, and draw 4 amps each.
LED Zone 1-4: 4 @ 7.2A each, 28.8A total
Actuator Zone 1: 4 @ 5A each, 20A total
Actuator Zone 2: 2 @ 4A each, 8A total
Total: 56.8A
For this project, I see two main options, component wise. I could either use SSRs, or MOSFETs to drive the LEDs/actuators.
I also could have a separate MOSFET/SSR to drive the 6 actuators, and tie them together in software, or, two MOSFETs/SSRs to drive the two groups together.
Which approach would you recommend, and why?
Also, since this is my first time with this high of current loads, i'm not sure on fuses. Should each bank of MOSFETs/SSRs have its own fuse?
