I have this simple program:
#include <p16f1503.inc>
__CONFIG _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _BOREN_OFF & _CLKOUTEN_ON
__CONFIG _CONFIG2, _WRT_OFF & _STVREN_OFF & _LVP_OFF
    org      0x00
    goto     setup
setup
    banksel  OSCCON
    movlw    b'01101010'  ; Int. osc. 4 MHz
    movwf    OSCCON
    banksel  OPTION_REG
    BCF      OPTION_REG, TMR0CS
    banksel  ANSELA
    clrf     ANSELA
    banksel  TRISA
    clrf     TRISA
    goto     main_loop
main_loop
    nop
    goto     main_loop
    end
What I would like to do is to enable CLKOUT pin, but it doesn't work... Am I missing something?
I am using:
  • IDE: MPLAB X IDE v1.20
  • Compiler: MPASM v5.45
and integrated software simulator...
[EDIT]
CLKOUT works just fine.. But sadly not in simulator.... Can someone explain reason for this behaviour.
I think the MPLAB SIM documentation sums up the issue perfectly:
MPLAB SIM only simulates to the register level, not the pin level, e.g., RB0 represents the value in bit0 of the PORTB register, not the value on the pin named RB0.
This makes sense as the simulator is a software model, and not actual device hardware.
Since CLKOUT is based on the chip hardware and isn't a SFR, it won't be simulated.
  • \$\begingroup\$ I hate using SE sites with iOS. The site is almost unusable! \$\endgroup\$ Commented Jun 19, 2012 at 1:26
  • \$\begingroup\$ Great! Exactly that was the missing piece of information I was looking for... \$\endgroup\$
    – PrimosK
    Commented Jun 19, 2012 at 6:45
