I have a wireless mouse that is powered by standard AA batteries. Periodically I will go to use the mouse and there's no response. Every time when this happens all I need to do is open up the mouse, re-seat the battery, and then everything works fine again. I want to emphasize that this is NOT simply because I am cycling power. There is a power switch on the back as well, and turning the power off and then on does not fix the mouse.
Why would re-seating the battery make a device work again when simply cycling power does not?
