I am working on early stage of product design and was hoping I could get some guidance/ help.
My product will use between 12 and 15 individual, small (less than 1" diameter) rotational, self-returning solenoids.
I do not yet know the force requirements, but anticipate they will be relatively modest.
When power is applied to the solenoids, they will rotate (45-90 degrees). When power is cut, they will need to return to their starting position.
There will be a single power on/off switch and we want all the solenoids to always engage and dis-engage together.
I am hoping that its possible to run all of the solenoids from one battery or set of batteries.
The solenoids would be engaged for approximately 5 seconds at a time. I am trying to understand power requirements and and also to figure out how many times could the set of solenoids be engaged before batteries are drained
The Solenoid I am looking at requires requires .93w
If I use a single D battery with 13,000 mAh capacity to power all 15 solenoids in the device, does that mean I should be able to power the 15 solenoids in the device approximately 931 times (13,000/15/.93)
I do not understand how to take into consideration that the solenoids will be powered up for only approx. 5 seconds at a time and how the hourly value in the mAh should be considered.
Thank you very much,
Jonathan
  • \$\begingroup\$ Hi Jonathan, what's the operating voltage and current for a single solenoid? \$\endgroup\$
    – TonyM
    Commented Jan 29, 2018 at 21:48
  • \$\begingroup\$ Its a 5volt DV (brandstrominstruments.com/… \$\endgroup\$
    – JonM
    Commented Jan 29, 2018 at 22:12
You're some of the way there in your thinking. To operate, each solenoid needs to be connected to a 5 V power supply. You say its a 0.93 W solenoid so it will draw around 0.186 A from that supply (P = V x A).
So to operate 15 at once, you need a power supply capable of providing 5 V at 2.79 A. That's a steady-state current, a sort of 'up and running' value.
Your 1.5 V 'D' cell supplies about 1.5 V nominal, which will drop under heavy load to a lower voltage. Therefore you could connect 4 in series to get 6 V, giving you some margin if the battery voltage drops.
The problem is that a typical alkaline cell won't give you 2.8 A peak. Revise your question to detail the battery you have and I can expand on this further.
  • \$\begingroup\$ Thanks, So I don't have a battery in mind, but rather trying to figure out if product is viable with a DC battery or rechargeable li on battery. Space and weight are both issues. I guess I am trying to understand the smallest battery that will be viable. The solenoids will be activated about 30 times per month on average, so low duty. Appreciate the help. \$\endgroup\$
    – JonM
    Commented Jan 29, 2018 at 22:48
