I'm working on UART using interrupts on Stm32F030 controller. I have done the following init.
void fnUart_Init(void)
USART_InitTypeDef USART_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
GPIO_InitTypeDef GPIO_InitStructure;
/* USART1 For Debug */
/* Enable GPIO clock */
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA , ENABLE);
/* Enable USART clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
/* USART1 Pins configuration */
GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_1);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_1);
/* Configure pins as AF pushpull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9 | GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* USARTx configured as follow:
- BaudRate = 115200 baud
- Word Length = 8 Bits
- Stop Bit = 1 Stop Bit
- Parity = No Parity
- Hardware flow control disabled (RTS and CTS signals)
- Receive and transmit enabled
USART_InitStructure.USART_BaudRate = 115200;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl =
USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
USART_Init(USART1, &USART_InitStructure);
/* NVIC configuration */
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);
/* Enable USART */
USART_Cmd(USART1, ENABLE);
UART2 Init
void fnUart2_Init(void)
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
/* Connect pin to Periph */
GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_1);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource3, GPIO_AF_1);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 | GPIO_Pin_3;
USART_Init(USART2, &USART_InitStructure);
NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPriority = 2;
USART_ITConfig(USART2,USART_IT_RXNE,ENABLE);
/* Enable USART */
USART_Cmd(USART2, ENABLE);
The IrqHandler is as follows
void USART1_IRQHandler(void)
printf("\n\r Inside ISR1");
I have the following printf function which prints data on UART2 when printf is called.
#define PUTCHAR_PROTOTYPE int std::fputc(int ch, FILE *f)
PUTCHAR_PROTOTYPE
/* Place your implementation of fputc here */
/* e.g. write a character to the USART */
USART_SendData(USART2, (uint8_t) ch);
/* Loop until transmit data register is empty */
while (USART_GetFlagStatus(USART2, USART_FLAG_TXE) == RESET)
return ch;
While loop has nothing running in it as of now.
Both the UART's are Initialized properly. This is verified by using printf
for both UART1
and UART2
. Now wrote this minimal code to test the interrupts. I'm sending any data via UART1 via Realterm software and USB-TTL converter and checking on UART2
whether USART1_IRQHandler()
is getting called or not. No response.
Also i was reading about the status and the interrupt flags. They are a bit confusing. When to use and clear those flags? But first i'm not getting why the execution is not entering the ISR? Did i miss something in the init? I do not have a debugger with me so using breakpoints and checking the execution is not applicable in my case. My goal is to send data received on UART1 to UART2 and data from UART2 to UART1. I'm using the standard periph libraries and not HAL libraries. Any suggestions?
printf()
from the ISR and called another function instead of it. And in that function i'm writing the code which is intended for theprintf()
. Also noticed one more thing. In the while loop i kept printing Hello on UART2 and as soon as i pressed the send button via the Terminal software on UART1, the printing stopped indefinitely. What could be the reason? \$\endgroup\$
