Can I charge series of 4 Maxwell BCAP3000 supercapacitors with constant current method using an adjustable Power Supply, and exceed the voltage rated for single cell?
What I mean is to charge the series of 4 ultracaps, that should be able to charge up to 10.8V, and have voltage higher than 2.7V on the power supply. I'm sorry if this question is somewhat silly, but this is my first take on supercaps connected in series. I've done single cell tests but never exceeded rated voltage on it. Therefore I have this small concern to solve.
They are rated for 2.7V. I have the manufaturers' balancing transistor boards attached to the cells, so single cell should be protected, but I am unsure if they are working since no LED is shining so far.
EDIT: Answers and comments provided solved my problem so this topic can be closed. Thanks for all of the concern and replies.
