This a kWh meter from a TV show. I'd like to know how many disc revolutions make 1 kWh. I think it's somehow coded in the whole data on the panel or could be derived from that information:
KwH meter
I found a formula
P = (3600 * Kh) / t
(t = time in seconds taken by the disc to complete one revolution, P = power in watts)
which gives me 138,(8) revolutions per 1 kWh but I am not sure I used the formula correctly.
    \$\begingroup\$ The Rr 13 8/9 is the speed in rpm at full load. \$\endgroup\$
    – PlasmaHH
    Commented Aug 8, 2018 at 9:42
  • \$\begingroup\$ @PlasmaHH And how much is full load? \$\endgroup\$
    – Schpunt
    Commented Aug 8, 2018 at 9:44
  • \$\begingroup\$ probably 200A (cl200) but I am not sure, I don't much about US meters. \$\endgroup\$
    – PlasmaHH
    Commented Aug 8, 2018 at 9:47
  • \$\begingroup\$ Strange. It's usually stated in clear text revolutions/kWh and not related to full load. Can you by any chance find a datasheet for it? \$\endgroup\$
    – winny
    Commented Aug 8, 2018 at 9:57
  • \$\begingroup\$ Googling around I found this which should answer all your questions and raise a ton more: usbr.gov/power/data/fist/fist3_10/vol3-10.pdf \$\endgroup\$
    – PlasmaHH
    Commented Aug 8, 2018 at 10:03
The Kh is (indeed) what you're after, and the formula you give seems to be correct, according to wikipedia, 'Electromechanical' section.
P = (3600 * Kh) / t         (for one rotation)
If we call the amount of rotations n, we get (P / n) = (3600 * Kh) / t
Or: P = (3600 * Kh) / (t * n)
Where:
    t = Time in seconds
    P = Power in Watts
That means the unit of Kh is:
  • (W / n) = (3600 * Kh) / s
  • (3600 * Kh) = W / (n * s)
  • Kh = W / (n * s * 3600)
  • And because s * 3600 = 1 hour: Kh = W / (h * n)
So if Kh = 7.2, and it takes 1 hour for the dial to rotate 1 time, you've used 7.2 Watts.
You want (n * kWh). Let's change that into (n * Wh) for now.
  • Divide everything on the right side through W: Kh = 1 / (Wh * n)
  • (n * Wh) = 1 / Kh
Now, we need to change Wh to kWh, so we multiply both sides with 1000:
  • (n * kWh) = 1000 / Kh
So for Kh = 7.2 you get 138.89 n*kWh or 138.89 rotations per kWh.
Your calculation is correct. :-)
