9
I'm connecting a Raspberry Pi to an LED and this video tutorial says that I need 270 Ω resistors. I only have 100 Ω, 1 kΩ, and 10 kΩ resistors with me. Is it okay if I use the 1 kΩ resistor?
13
Choosing the series resistor for an LED:
  • You need to know the forward voltage of your LED (Vf in datasheet) This will vary depending on the colour. For example a typical red LED has a VF of ~2V, a blue LED a Vf of ~3.5V.
  • You then need to decide on the current you wish to run your LED at. It needs to be under the maximum continuous current (Imax) specified in the datasheet. A typical 5mm indicator LED (as seen in the tutorial) has an Imax of 20mA.
    As a rough guide, for this type of LED, it will be just visible at 1-2mA, and quite usable for an indoor indicator at 5-10mA. At 20mA it will be very bright (painfully so if an ultra-bright LED viewed too close)
  • Lets say you go for 10mA, and have a red LED with a VF of 2V. I'm assuming the the Rpi supply voltage is 3.3V, so the pin output high will be 3.3V. The resistor goes in series with the LED. The voltage across the resistor will be the supply voltage minus the LED Vf. With this information, to calculate the resistor value we use Ohm's law:
    R = V/I = (3.3V - 2V) / 0.010A = 130Ω
    In the case of the supply voltage being lower than the LED Vf, the above formula does not apply (supply V must be >Vf) The LED will not turn on (if just under Vf a small amount of current may flow, see the I-C curve below, it's not a perfectly sharp corner at the point marked Vd [aka Vf]) See edit at end for solution.
So you could use the 100Ω resistor and have an LED current of 13mA, ((3.3V - 2V) / 100Ω = 13mA) which should be within specs for most standard LEDs. With the 1kΩ resistor, the LED will be rather dim at only 1.3mA.
Just in case you wonder why the LEDs voltage seems to be fixed at a certain voltage, it's not quite that simple, but a useful approximation. Since an LED is a type of diode, when the voltage across it is lower than it's Vf, the LED looks like a very high impedance and no current passes. When the LED reaches it's Vf, the current rises very sharply for tiny change in voltage, so it suddenly looks low impedance. This means if we put a resistor in series with it, we can choose a wide range of currents for only a small change in Vf.
To illustrate this, have a look at this diagram which displays a typical diodes I-V curve (current in relation to voltage):
Diode I-V curve
You can see when the voltage reaches the point Vd, the current rises sharply for a very small change in voltage, so we can "choose" a current anywhere in this range and get a similar voltage.
What about driving LEDs with a higher Vf than the available supply voltage?
In this case, we need to step the voltage up, and fortunately there are many cheap ICs available to do this for us. They cone in various varieties, and use linear, constant current, buck/boost (switched inductor) and charge pump (switched capacitor) topologies.
For example, the NCP5006 will drive up to 5 white/blue LEDs in series from a 2.7V - 5.5V supply:
NCP5006
For a multi-channel option that can control each LED individually, the charge pump based TPS60250 will drive up to 7 white/blue LEDs from an input of down to 3V. I2C is used for the control interface:
TPS60250
These were picked at random from over 700 options on Farnell (under "LED driver" and boost/charge pump options selected)
  • \$\begingroup\$ Let's say you have a voltage of 3.3V output at the regulator on your board. If a (typical) blue LED has a forward voltage of 3.5V, how will it work in this scenario? E.g., the calculation of LED current then would be (3.3V - 3.5V)/100 ohm, giving a negative value. Or qualitatively, the forward voltage is GREATER than the voltage we're applying... A little confused about this. \$\endgroup\$
    – boardbite
    Commented Sep 1, 2012 at 6:05
  • \$\begingroup\$ @boardbite - see edits. The supply voltage must be higher than LED Vf, so an LED with a Vf 3.5V won't work for 3.3V. \$\endgroup\$
    – Oli Glaser
    Commented Sep 1, 2012 at 8:32
  • \$\begingroup\$ Oli, interestingly though, it seems a LOT of the RGB LEDs (smd-types found on Digikey, Mouser, etc.) have 3.3V or even 3.4V as the forward voltage for the Green and Blue bits of the RGB. But I thought 3.3V was a fairly common circuit-wide voltage -- do you have any comment on this? At the least, are LEDs with Vf exactly = 3.3V runnable on a 3.3V supply? (appears to be the case looking at the sharp curve in your Answer) \$\endgroup\$
    – boardbite
    Commented Sep 1, 2012 at 11:12
    \$\begingroup\$ @boardbite - Yes, it's quite a common issue - I added some more detail on how to drive the LEDs in this situation. Ideally you will have at least a few hundred mV of headroom, otherwise regulating the current becomes difficult, so for an LED with the same Vf as supply voltage, use a boost/charge pump driver. \$\endgroup\$
    – Oli Glaser
    Commented Sep 1, 2012 at 16:47
5
1K will work fine. Alternatively, three 100 ohm resistors in series will give you 300 ohms, which is so close to 270 that you won't know the difference. But either way is fine if all you want to do is to observe the LED turning on or off.
We'll need Ohm's Law and Kirchhoff's Voltage Law (KVL) for that. KVL says that the total of the voltages in a closed loop is zero. The RPi's output voltage is a given, that's 3.3 V. The LED's voltage is also more or less constant, though it depends on the color, for a red LED 2 V is a typical value. Then there's only one component left and that's the resistor, which, due to Kirchhoff, will have 3.3 V - 2 V = 1.3 V across it.
The resistor controls the current through the LED. Ohm says the current is voltage / resistance, or to put it differently resistance = voltage / current. An indicator LED will often be specified at 20 mA (70 % of Digikey's 15 000 LEDs are). They will work at less current but shine less brightly. So let's assume you have a 20 mA LED and you choose for 20 mA because you also want to see it light up on a bright sunny day. Then the resistance should be
\$ R = \dfrac{V}{I} = \dfrac{1.3 V}{20 mA} = 65 \Omega \$
If you only have 100 Ω resistors you can make a 65 Ω by placing two 100 Ωs in series and a third one in parallel with that. Or you can try with just a 100 Ω, then
\$ I = \dfrac{1.3 V}{100 \Omega} = 13 mA \$
In any case always check the LED's datasheet for the forward voltage drop and maximum allowed current. The forward voltage you can also measure by using a safe value for the series resistor (the 1 kΩ is fine).
