What is a Node?
In electrical engineering, a node is any point on a circuit where the terminals of two or more circuit elements meet.
An image from my textbook...
Why is the node rightward of Node 3 (GND) ignored?
It seems to have the same voltage as Node 2, in which case I wouldn't solve for both. It'd be great if someone clarified because I'm not confident in my reasoning.
  • \$\begingroup\$ That node rightward of Node 3 (GND) is the same Node 3(GND) actually. \$\endgroup\$
    – user115094
    Commented Oct 12, 2018 at 1:09
    \$\begingroup\$ Ben, I think your only confusion is where it says "two or more." Node 3 has four terminals running to it. Node 2 has three terminals. Note 1 has three terminals. You don't get to call something two different nodes if the only thing going on is just more "wire" attaching them. And for any particular circuit, you are allowed to call any one of them "0" or ground. But only one. Here is the same circuit, without ground assigned. \$\endgroup\$
    – jonk
    Commented Oct 12, 2018 at 1:19
TL;DR Nodes are the wires on schematics, not the dots.
In circuit analysis, a node is a collection of points, at the same voltage, connected by ideal wires, that can be treated as a single point for all purposes.
That means that these ideal wires have zero resistance, zero inductance, zero capacitance to anything else, and zero electrical length.
In the case of your diagram, there is a single node connecting the bottom of iA, R1, iB and R3. This is indicated by the fact that that connection is drawn as an ideal wire.
The multiple connection dots on that node are a drawing convenience. We generally find that drawings restricted to vertical and horizontal wires are tidier and easier to read than if wires take other angles, which a single dot for this node would entail.
  • \$\begingroup\$ Right, I can see the dot lets us avoid a diagonal wire; and I appreciate your first paragraph. It tells it as it is. Thank you. \$\endgroup\$
    – Ben
    Commented Oct 12, 2018 at 17:32
