In one of my small projects I use STMF103C8T6 as MCU and SPI memory W25Q128 of Winbond to store a data. The memory chip connected to SPI1. Here is a part of the scheme:
The code is mostly generated by CubeMX. I've only added some code to communicate with the memory chip:
Initialization:
SPI_HandleTypeDef hspi1;
static void MX_SPI1_Init(void)
hspi1.Instance = SPI1;
hspi1.Init.Mode = SPI_MODE_MASTER;
hspi1.Init.Direction = SPI_DIRECTION_2LINES;
hspi1.Init.DataSize = SPI_DATASIZE_8BIT;
hspi1.Init.CLKPolarity = SPI_POLARITY_LOW;
hspi1.Init.CLKPhase = SPI_PHASE_1EDGE;
hspi1.Init.NSS = SPI_NSS_SOFT;
hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_32;
hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
hspi1.Init.TIMode = SPI_TIMODE_DISABLE;
hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
hspi1.Init.CRCPolynomial = 10;
if (HAL_SPI_Init(&hspi1) != HAL_OK)
_Error_Handler(__FILE__, __LINE__);
W25Q128 code:
#define CS_Pin GPIO_PIN_3
#define CS_GPIO_Port GPIOA
#define ChipSelect() HAL_GPIO_WritePin(CS_GPIO_Port, CS_Pin, GPIO_PIN_RESET)
#define ChipDeselect() HAL_GPIO_WritePin(CS_GPIO_Port, CS_Pin, GPIO_PIN_SET)
#define COMMAND_IDENTIFICATION 0x90
uint8_t buffer_tx[4];
uint8_t buffer_rx[2];
uint16_t GetIdentification()
buffer_tx[0] = COMMAND_IDENTIFICATION;
buffer_tx[1] = 0x0;
buffer_tx[2] = 0x0;
buffer_tx[3] = 0x0;
ChipSelect();
HAL_SPI_Transmit(&hspi1, buffer_tx, 4, 1000); // send 0x90, 0x0, 0x0, 0x0
HAL_SPI_Receive(&hspi1, buffer_rx, 2, 1000); // receive 0xFF, 0xFF
ChipDeselect();
return ((uint8_t)buffer_rx[0] << 8) | (uint8_t)buffer_rx[1];
int main(void)
MX_SPI1_Init();
HAL_Delay(1000);
uint16_t id = GetIdentification();
printf("Manufacturer ID: 0x%.4X\r\n", id);
while
According to the datasheet to get chip manufacturer code I need to send 0x90 and 3 dummy bytes. The chip should return 0xEF, 0x17. But for some reason I receive 2 bytes of 0xFF. Ok, I've changed the chip twice in the PCB but without results. I still receive 0xFF, 0xFF. I've connected logic analyzer to the chip on the PCB and to my astonishment I get the following picture:
According to the diagram everything is Ok. The chip sends 0xEF, 0x17 as expected. But for some reason my STM32 doesn't see that.
I've rechecked the PCB, I reinstalled a few chips, I've tried W25Q128 and W25Q64 - all failed, I receive only 0xFF, 0xFF instead of real data. What could it be and how can I fix that?
The full project is here.
