I have made a preamplifier with filter but before asking that question I decided to open a specific question about a MOSFET audio power amplifier. It seems an old one and I cannot find its data-sheet so I couldn’t share it. Below is its right inputs and right outputs:
From its banana jack outputs it is powering a 8Ohm 60W speaker. Speaker is used for some experimental setup at low frequencies from 0.1Hz to 100Hz max.
I noticed that they are using sym input which is coming from a function generator set to much higher than line voltages like 1V. One of the reason is that same function generator output also goes to a scope and a DAQ. So basically they don’t use typical audio inputs.
The preamplifier I made will replace the function generator and will be coupled to sym input. But I don’t know the input impedance of this input.
Regarding the photo my question is; what is sym input used for? I couldn’t find what sym and asym stand for? And what can be the ground lift switch?
