How would I limit speed of a DC motor being used as a generator? For a project where I have to make a wind turbine that will automatically limit speed of rotation once past a certain value. Thanks :)
1 Answer
A few ideas:
- Rotate the motor so the blades are out of the wind
- Change the pitch of the blades by rotating them at the base, so they are no longer effective, if they can have that capability. Also called 'feathering'.
- Use a mechanical brake (you could use a mechanical clutch but that would allow the blades to turn faster, which could cause problems).
- Apply additional load to the motor, dumping heat into a dummy load if necessary
\$\begingroup\$ Your 2 is pitch control... \$\endgroup\$ Commented Nov 18, 2018 at 14:27
