There are loop/mesh analysis and node analysis corresponding to Kirchhoff’s voltage law (KVL) and Kirchhoff’s current law (KCL), respectively.
Let's consider three elements, R,L,C, connected serially in the simplest way to some external voltage source.
With KVL and a charge variable \$q\$, we have \$(-\omega^2L+\frac{1}{C}+j\omega R)q(\omega)=v_\mathrm{ext}\$.
Let's consider three elements, R,L,C, connected parallelly in the simplest way to some external current source. With KCL and a flux variable \$\phi\$, we have \$(-\omega^2C+\frac{1}{L}+\frac{j\omega}{R})\phi(\omega)=i_\mathrm{ext}\$.
We see that such a resistor in the KVL of an AC simple RLC circuit can lead to a term proportional to \$j\omega R\$, which becomes a term proportional to \$\frac{j\omega}{R}\$ in KCL. And all other terms are real.
(Surely, if you divide or multiply these equations by \$j\omega\$, you get the impedances like \$j\omega L,\frac{1}{j\omega C},R\$.)
We know resistance entails dissipation, which is naturally related to imaginary terms. So I don't think these equation forms are meaningless. I hope to understand.
However, the imaginary \$\frac{j\omega}{R}\$ term in node analysis KCL seems to be smaller and smaller as the resistance increases. It appears somewhat counterintuitive. How to understand this?
