I'm working with a Microchip ATSAML21J18B ARM microcontroller and learning how to set up an ADC input. Coming from the AVR world, things are rather more complicated.
The ADC features (datasheet pg 1030, §42.4) indicate that there are up to 20 analog inputs. Examining the I/O multiplexing section (pg 29-30, §7.1), I can see that there are 20 AIN[xx]
designations in the ADC column of the pin function table. I believe I correctly understand that some of these pins reference VDDANA
, VDDIO
, or VSWOUT
based on the values in the Supply column.
I understand that you can also combine channels for various reasons that I'm not familiar with.
Using Atmel "Start", it has generated the following ADC init method:
int32_t adc_async_init(struct adc_async_descriptor *const descr, void *const hw, uint8_t *channel_map, uint8_t channel_max, uint8_t channel_amount, struct adc_async_channel_descriptor *const descr_ch, void *const func) { int32_t init_status; struct _adc_async_device *device; ASSERT(descr && hw && channel_map && channel_amount && descr_ch); ASSERT(channel_amount <= (channel_max + 1)); device = &descr->device; for (uint8_t i = 0; i <= channel_max; i++) channel_map[i] = 0xFF; descr->channel_map = channel_map; descr->channel_max = channel_max; descr->channel_amount = channel_amount; descr->descr_ch = descr_ch; init_status = _adc_async_init(device, hw); if (init_status) return init_status; device->adc_async_ch_cb.convert_done = adc_async_channel_conversion_done; device->adc_async_cb.window_cb = adc_async_window_threshold_reached; device->adc_async_cb.error_cb = adc_async_error_occured; return ERR_NONE; }
My question is, what are the arguments map
, max
, and amount
for?
The generated example shows the call to this method as so:
// Definitions preceding main()
#define ADC_0_CH_AMOUNT 1
#define ADC_0_CH_MAX 0
struct adc_async_descriptor ADC_0;
struct adc_async_channel_descriptor ADC_0_ch[ADC_0_CH_AMOUNT];
static uint8_t ADC_0_map[ADC_0_CH_MAX + 1];
// ADC init
adc_async_init(&ADC_0,
ADC,
ADC_0_map,
ADC_0_CH_MAX,
ADC_0_CH_AMOUNT,
&ADC_0_ch[0],
(void *)NULL);
I assume these have something to do with combining channels, but I admit I'm very confused about how to set up a single channel just to do a basic 8-bit conversion.
Perhaps a better question title would be, "Explain Microchip/Atmel's ADC implementation on ATSAML21 like I'm 5!" There are so many extra features and options that I'm completely lost.
