I am using the MSP-EXP430F5438 evaluation board, which has pushbuttons connected to P2.6 and P2.7 and LEDs connected to P1.0 and P1.1.
I want to make it such that P2.6 sets the LEDs on and P2.7 resets them. To do that, I wrote the following code:
#include "msp430x54x.h"
int main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop watchdog timer
P1DIR |= BIT0 + BIT1; // Set P1.0 and P1.1 to output direction
P2DIR = 0x00; // Set the P2 to input direction
P1OUT = 0x00; // Blank all LEDs
while(1)
if(P2IN & 0x40) // When P2.6 is pushed
P1OUT = 0x03;
if(P2IN & 0x80) // When P2.7 is pushed
P1OUT = 0x00;
__delay_cycles(100000);
But it doesn't work properly; sometimes it works erratically (the LEDs turn on when P2.6 is pressed but they don't turn off when P2.7 is pressed), sometimes it doesn't work at all.
Any ideas?
