I have written a code which takes two digit number from laptop and changes the PWM dutycycle to that number. It is part of a bigger requirement where I need to control motor speed over UART.
#include "io430g2553.h"
#include <stdint.h>
void PWM(uint8_t duty_cycle);
void PWM_Config();
int main( void )
// Stop watchdog timer to prevent time out reset
WDTCTL = WDTPW + WDTHOLD;
BCSCTL1 = CALBC1_1MHZ; // Run at 1 MHz
DCOCTL = CALDCO_1MHZ; // Run at 1 MHz
PWM_Config();
PWM(5);
__delay_cycles(5000000);
PWM(15);
PWM(25);
PWM(50);
PWM(25);
PWM(15);
PWM(5);
while(1)
void PWM_Config()
P1OUT &= 0x00; // Clearing P1OUT
P1SEL |= BIT6 ;
P1SEL2 &= ~BIT6 ;
P1DIR |= BIT6; // Configuring P1.6 as Output
TA0CTL =0;
TA0CTL |= TACLR;
TA0CCR1 |= (duty_cycle*100);
TA0CCR0 |= 10000;
TA0CTL |= TASSEL_2 + MC_1 + ID_0;// Register TA0CTL -> SMCLK/8, Up mode
TA0CCTL1 |= OUTMOD_7 ;//Set/Reset Mode
TA0CCTL0 &= ~CCIE; // Interrupt Disabled
Edited My question on received comment:
The problem with the void PWM(uint8_t duty_cycle) function is that first time it generates the correct PWM at P1.6, next if it is given a value it changes PWM to that DC, but I can not go back to lower DC.
the fisrt 2 PWM functions in the code changes to correct duty cycle PWM(5),PWM(15) then the rest of PWM values do not produce desired dutycycle.
I am not able to troubleshoot where am I wrong, can any1 help?
