I'm trying to obtain the output resistance (resistance from collector node) of the following circuit
By inspection, it should be the output resistance of a common emitter amplifier with degeneration
$$R_o = r_o(1+g_mR_1)$$
This transistor has
$$I_c = 20 mA $$ $$V_A = 36$$ $$r_o = \frac{36 V}{22mA} \approx 2k\Omega$$ $$ g_m = \frac{20 mA}{25 mV} \approx 720 m\Omega^{-1}$$
So its output resistance should be
$$R_o = 2k\Omega(1+720 m\Omega^{-1}250\Omega) \approx 360 k\Omega$$
However, the simulations are giving strange results. I tried simulating a small sinusoidal voltage at the collector and measuring the current as to get the resistance of the node, but trying to get the voltage amplitude below 1 V yields very strange results. Here are some captures of the voltage at the collector, which should be sinusoidal, but it isn't. The frequency of operation is 1 kHz
1000 mV ampltiude:
100 mV amplitude:
10 mV amplitude:
