So I am using the ATTiny10 for the first time, and I noticed that even after setting the clock pre-scaler register correctly (0x00 in my case) I had to define a value called F_CPU
for the _delay()
function to work correctly. but when going over the code example I have there was #define F_CPU 8000000UL
. What does the UL
mean?
Also if someone can recommend a good book to start with microcontrollers that would be appreciated, too many registers and setup conditions it's overwhelming!.
8000000
as an Unsigned Long integer - also sometimes known as auint32_t
. See this question on Stack Overflow. \$\endgroup\$
