Background:
I have a device that interfaces with a motor controller over RS-485 via an RJ45 socket. Currently, the port is a standard 4x2 RJ45 connector with the RS-485 using pins 2 and 7.
Currently my startup procedure tries to connect to the controller 3 times before notifying the user Device Cannot be found. Check cable
Problem:
I would like a way to electronically check if the cable is plugged in. By any chance, do 10-pin RJ45 sockets exist where two pins short if a cable is plugged in? If so, what is this feature called? If not, what is a solution used to detect if a cable is present in the system?
