This might be a very stupid question, but I can't seem to figure this out and I'm going nuts thinking about it.
Assuming you are trying to adjust the fixed bias of a tetrode push pull pair in a tube amp. In many amps, for convenience, the cathode will have a 1 ohm resistor connecting it to the ground, so you can easily use a multimeter to measure the voltage and thus the current flowing through the tetrode.
My confusion arises when trying to comprehend how the resistance of the multimeter probes themselves would contribute to this measurement.
I realize the probes are likely not thin enough wire or long enough to make any difference, but assume the resistance of each probe wire is also 1 ohm for this scenario.
Would it make any difference here?
