I currently have a PWM 12/24v (auto commute) with ~18V as input and a 12V battery in the output.
I wanted to switch to 24V battery and I thought about going ~36v solar panel. (18V * 2)
Then I saw online some examples of putting more in series for a higher voltage, like this one:
These solar panels are 100W and can go up to ~22V. So if I'm correct this schematic will send about 66V to the PWM/MPPT to charge a 24V battery. (two 12V in series.)
Can a charge controller handle whatever amount of voltage? And is there on this aspect a difference between MPPT and PWM?
And is there a difference in efficiency between sending 66V or 33V?
