Possibly a very basic question, but I am trying to add a secondary sub-board (receiver) to a micro controller for roller shutter door.
The control board already has a right angle 6-way pinout with 2.54mm pitch. This connects directly into the existing sub-board (receiver).
What I would like to do is to somehow passthrough the pinout to another receiver with the same pinout using simple wires.
The image below shows the current state with the purple existing board connected directly to the right angle pin-out from the control board. The new board is in blue, however they can be swapped around. The order doesn't matter.
My question is: how can I connect a secondary board (shown in blue) to the existing pins? I can't access the pins directly as there are plugged in. I'm guessing I would need some kind of pass-through device or splitter.
EDIT: Would the below configuration work on a stripboard?
