I am trying to design a more linear amplifier by using less linear amplifiers in a push-pull configuration. IE run the signal through a 180deg splitter, each leg running through identical amplifiers then recombining through a 180deg combiner.
This should increase the OIP3, OIP2, and P1dB but what happens to the noise figure? I would think it should decrease by 3dB but I'm not sure that is right and am having trouble finding information on it.
Are there any other consequences of doing this with amplifiers besides added costs of more amplifiers?
EDIT:
Frequency Band: HF (3-30Mhz)
Power: Max 12dBm
For example
As seen here in the second half, OIP3 and P1dB should improve by 3dB but no mention of the noise figure and that is what I am trying to figure out.
