Is there a way to find the last address or last page of the program which is stored in an STM32(F1) using a HAL (or LL?) function?
Background: I'm using EEPROM emulation in Flash and this works great. I changed the library from a hardcoded page to be used for EEPROM emulation to a variable one, to be able to implement wear leveling.
However, to know which pages can be used, I need to know where the program 'stops', i.e. the last address or page used by the program being executed, not to overwrite the program itself.
Also I'm a bit confused about the pages used and the size of each page. I'm using this library:
https://github.com/nimaltd/EEPROM/blob/master/eeprom.c (credits to Nima Askari).
Which defines for STM32F103C8T6 (low density F1) 1 KB page sizes and a max page of 31. Why 31? I would expect 63 as it has 64 KB. Although I noticed when using page 15, it overwrote my program which is around 30 KB in size. (this part is solved, see my answer below).
Of course I can use the size of the program (see below), but this varies while I program, and besides it's too tedious to change/calculate the page number every time, I might forget it too.
arm-none-eabi-size FuzzTester3.elf
text data bss dec hex filename
26632 236 3104 29972 7514 FuzzTester3.elf
__text_end__
and const data__rodata_end__
. I canextern
these in my C code - something likeextern uint32_t *__rodata_end__;
and then use these 'variables' in my code. Once the compiler & linker finish doing their jobs, these values are then automatically substituted into my code where needed. \$\endgroup\$__fini_array_end
at the last used location in Flash. So you'd probably declare it asextern uint32_t __fini_array_end;
in your code and then use&__fini_array_end
to work out the start of the next page to use as simulated EEPROM \$\endgroup\$__init_array_end
,__preinit_array_end
, etc. \$\endgroup\$
